Old 09-06-2012, 11:57 AM   #1
stocksofar
stocksofar is on a distinguished road
Crank Sensor Problem
I Have An 01 Alero 3.4l And I Constantly Have A Crank Sensor Code. I Replaced Both The 3x And The 24x Crank Sensor. Wondering If There Is Any Common Problems That Anyone Has Encountered That Might Help Me Out. It Would Be Greatly Apreciated. Thank You.
stocksofar is offline   Reply With Quote
Old 09-06-2012, 05:03 PM   #2
zearchyo
zearchyo's Avatar
zearchyo is on a distinguished road
bump
yeah right!
zearchyo is offline   Reply With Quote
Old 09-06-2012, 07:13 PM   #3
It's 7x and 24x, don't know if maybe you picked up the wrong one or not
Old 09-07-2012, 01:13 PM   #4
stocksofar
Yeah thats what i meant. But no I know for a fact that I replaced the correct ones. As you know there is 2 of them, the one on the side of the block, and the one under the harmonic balancer. Both got replaced. But the same code appears. I dont know if maybe I have a short to ground or what. Or maybe even a frayed or broken wire. I read the signals with a Genysis scanner and I have a response out of both sensors but the 24x sensor doesnt like to read accurately.
Old 09-07-2012, 02:14 PM   #5
unchained01
unchained01 is on a distinguished road
when crank sensors are replaced they need calibrated/relearn by tech2 , hptuner or dhp tuner
unchained01 is offline   Reply With Quote
Old 09-07-2012, 05:00 PM   #6
If it's the 24x giving you problems, how is the ring on the inside of the balancer? If it's chipped or bent, it will cause problems
Old 09-07-2012, 06:34 PM   #7
There is a trigger wire that goes from the ign module down to the 7x sensor. It is a twisted 2 wire connection. With exposure to heat back there the wire will sometimes fuse and skew the signal sent to the module to start the firing order of the coils. I would replace that lead, I bet it solves the poblem as this is a very common issue
Old 09-08-2012, 11:46 AM   #8
i had a problem like this and i replaced both sensors and the car would still stall out. i tried everything. i ended up putting my stock ECU in and it fixed it. you may have a bad ECU. hope this helps.
