Old 01-15-2013, 04:36 AM   #1
Power Steering making noise AGAIN
My power steering pump is really making some noises. It seems to only happen when it's really cold outside. It's been in the teens at night and 20's/low 30's during the day... Not sure why it's having an effect on my power steering pump, but wondered if anyone else experiences it. Seems to work fine, just makes a lot of noise.
Old 01-15-2013, 06:42 AM   #2
Have you checked the fluid? I know when its low it can cause it to be noisy.
Old 01-15-2013, 07:18 AM   #3
may even try flushing it with ATF.
Old 01-15-2013, 08:47 AM   #4
TheEdgeofSanity
TheEdgeofSanity's Avatar
when I still had my alero, my power steering was noticeably louder when it was really cold... my mechanic said it was a combination of the fluid being much more viscous so its harder for the pump to move it and also he said since my car was higher in miles that my power steering rack was more worn and the internal seals are not as good, especially when cold. I'd say that maybe change out the fluid with a new, high quality fluid and see if that helps
2000 Chevrolet Malibu LS
Old 01-15-2013, 04:36 PM   #5
Gah! I just replaced the darn thing last year and put all new fluids in! What brand should I use? Probably has something to do with the steering rack... I'm pretty sure everything else in the power steering system was replaced.
