Old 03-27-2013, 01:57 AM   #1
WIALERO
WIALERO's Avatar
WIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these parts
Send a message via Skype™ to WIALERO
temp problem :( !
Well today i installed a new thermostat and the old one when i turned off the heat it it would go passed half way and would sit there and i put a new one in and even with the heat on it went passed way and even driving at 70 it still sits there and oil temp reads 220 when im at idle for 5min i have pics and can send them to you im here on a phone so i cant upload them but how long will it take to break in i put 10 miles on it the way its looking right now i am probably not going to ass if i have to replace the headgasgets or is it normal to see it overheat for a while for the new thermostat to break in?
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog View Post
He no crazy, he WIALERO!!
WIALERO is offline   Reply With Quote
Old 03-27-2013, 02:17 AM   #2
lol....the new thermostat doesn't need to break in.....you either have bad LIMG or HG.
Old 03-27-2013, 02:30 AM   #3
WIALERO
WIALERO's Avatar
Well hopefully its not the head gasget but it could ne a possibility there is some moisture around the heads
Old 03-27-2013, 02:45 AM   #4
WIALERO
WIALERO's Avatar
Hell with it il replace the head gasgets friday
Old 03-27-2013, 03:37 AM   #5
Are the fans comng on at all?
Old 03-27-2013, 03:44 AM   #6
WIALERO
WIALERO's Avatar
Nope even got new relays for both fans to
Old 03-27-2013, 04:12 AM   #7
WIALERO
WIALERO's Avatar
This weekend or friday ima replace both head gasgets, limg, temp sensor, coolant and idle air control needed a new one anyways car idles funny sometimes
And with the fan issue ima run a power wire to them with ground to see if they work and if they do il run it to a switch but if not il get new ones
Old 03-27-2013, 04:23 AM   #8
A scanner such as HP Tuners can manually switch on the fans. I don't know if a place like Autozone has that capability. Also scan it for Engine Coolant Temp (ECT) or shut it off after it heats up, unplug the ECT sensor and measure the resistance on the sensor.
Old 03-27-2013, 07:33 AM   #9
Mike The Canadian
Mike The Canadian is on a distinguished road
It's possible that the system need to be bled or burped...
It's real quick to go and replace the head gasket after the car went from running cool to running hot after a T-Stat change...
Mike The Canadian is offline   Reply With Quote
Old 03-27-2013, 08:07 AM   #10
did you ever try my suggestion of jumping the plug for the temp sensor to see if the fans come on
Old 03-27-2013, 08:52 AM   #11
Pm me. I possibly can come help you
Old 03-27-2013, 09:42 AM   #12
I'll second this......
Old 03-27-2013, 07:22 PM   #13
WIALERO
WIALERO's Avatar
[quote=Mike The Canadian;636391]It's possible that the system need to be bled or burped...
It's real quick to go and replace the head gasket after the car went from running cool to running hot after a T-Stat change...[/QUOT
So basically flush the system? And us there a drain spout on the bottom of the radiator?
Old 03-27-2013, 07:23 PM   #14
WIALERO
WIALERO's Avatar
Not yet ima try it tomarrow when i have off
Old 03-27-2013, 07:23 PM   #15
WIALERO
WIALERO's Avatar
Car overheated once for 5u min then came back down and the fans did not turn on
Old 03-27-2013, 07:43 PM   #16
I don't care about that...take a extra piece of wire, unplug the connector from the temperature sensor, put one end into each of the two pins and turn the key on...then do the fans come on...my car got about half way between 3/4 and red one time since I owned it and it was because the temp sensor was bad and not telling the fans to kick on...We jumped the plug and it showed the fans worked when the circuit was completed, replaced the sensor and haven't had that issue since...the best thing about it is that it is free trouble shooting to figure out if a $30 part is part of a problem you are thinking will be much more expensive
Old 03-27-2013, 07:47 PM   #17
Mike The Canadian
The system is burped via. a bleeder near the water pump....
Try and search it online, I don't have a link off-hand...
If there's air in the system your car will over heat and you'll have no heat as well..
Rad fans is likely a separate issue that should be addressed as well because it will heat up when you sit around in the city.
Old 03-27-2013, 09:30 PM   #18
WIALERO
WIALERO's Avatar
Well still have really good heat
Old 03-27-2013, 09:32 PM   #19
WIALERO
WIALERO's Avatar
Sounds easy il try it later when i get off work
Old 03-27-2013, 09:52 PM   #20
zzyzzx
zzyzzx's Avatar
Was the thermostat that you took out stuck open?
If not, did you test the thermostat that you took out?
I usually just put them in water in a pan on the stove and see if it opens all the way. I do that with new ones before I install them as well, just to test them.
