06-25-2013, 12:54 AM
Matt's newest insane project (brake porn inside)
06-25-2013, 01:09 AM
Just simply beautiful man. Very nice.
Me, ill stick with the baers.
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-25-2013, 04:09 AM
Holy cow matt! Nice stuff man!
06-25-2013, 05:09 AM
06-25-2013, 07:40 AM
06-25-2013, 09:26 AM
only 3mm wheel spacer... I had to order 1 inch spacer on mine...
tell me your feelings once the road test will be done, because I think that our master cylinders are not done to push enough fluid to fill fast enough these big brakes kit..
I have a set of corvette z06 2008 on mine... 6 pots fronts and 4 pots rears
I don't remember if the corvette had 3/16 or 1/4 brake lines...
If you don't mind how much did these cost ??
06-25-2013, 09:42 AM
I specifically went this way because the caliper is very compact and allows me to still run 17" wheels. The calipers are forged aluminum, with machined stainless steel pistons and weigh just under 5 pounds each! I'm losing about 8 pounds of weight on each corner!
These calipers are sized to work well with a stock C5 master cylinder, which is basically what we have. I have had base C6 brakes on my car for the past 2 years, and they work fine. The C6Z06 calipers do have a much higher fluid requirement.
I'd rather not make the cost public knowledge.
06-25-2013, 09:54 AM
wow those look awesome.
06-25-2013, 10:39 AM
I Have ONE NUT
Great job Matt! Looking forward to hearing how they perform.
06-25-2013, 10:46 AM
Can't say I have heard of that company or seen J hook rotors before. Interesting stuff!
06-25-2013, 11:47 AM
You dont need this donatoon time
06-25-2013, 01:48 PM
price?
06-25-2013, 02:05 PM
Instead of thread skimming read the whole thread and your question eill be answered
06-25-2013, 02:46 PM
Yeah I saw that 5lbs, I'm super jealous of that extremely light weight, that is a good advantage, even the rotors must be a lot lighter than mine... I suspect that mine's are filled with concrete lol...I think I'll install an adjustable prop valve
I don't know if a c6z06 master would bolt to the alero stock brake booster ??
06-25-2013, 03:00 PM
C6Z06 rotors usually come in around 25.6 lbs.
Base C6 rotors are about 21.5 lbs.
The AP rotors with the aluminum bell are only 17.6 lbs.
I have no idea what C6Z06 calipers weigh.
I give a bit back with the brake pads. The friction puck is 20mm thick!
06-25-2013, 03:57 PM
well yea thire race car brakes lol
06-25-2013, 05:36 PM
Interesting looking rotors. I like
Wear protective eyewear before you do the first hard stop
06-25-2013, 07:03 PM
Very nice! A couple K into brakes....crazy! Wish i had that kind of loot
06-25-2013, 09:59 PM
I didn't skim, I just didn't read it LOL!!!
I was lost in the porn, LOL!!!
LOL!!!
06-25-2013, 10:00 PM
where do you pick up the spacers up at?
