09-10-2013, 08:00 PM
15.65 @ 87.3 MPH
Car won't start with 1/4 tank of fuel
Anytime my car gets to the 1/4 mark, my car won't start. Once I fill it up a bit, it'll start on first key. Has anyone ever had this issue? I'm thinking it's the fuel pump, but I thought I'd get some opinions before I just change it.
09-10-2013, 08:04 PM
Could your fuel gauge be off?
Originally Posted by Oldsnut
Originally Posted by tipnitty
09-10-2013, 11:13 PM
That's my thought too... fuel gauge is off and it is actually empty! Keep track of your mileage per tank to when you get that far and see if it is actually empty or very low...
09-10-2013, 11:44 PM
15.65 @ 87.3 MPH
Nope! Highly unlikely I'd say. I usually get ~400 KM per tank and I'm usually around ~300 KM when I get to 1/4 of a tank which is where it was the last 3 times it wouldn't start. I track my mileage per full tank so I wouldn't think so. Also I kept on cranking it over so at some point if it was empty, I would think I would have burnt the fuel pump by now.
09-12-2013, 12:43 AM
Starter will go before the fuel pump.
Also - when it does this, how much gas do you put into the car, on a total fill up?
That's a big hint there.
Past that - it could be a break in the inlet pipe to the pump, like a crack in the straw in your iced tea or soft drink. Above a certain point, it sucks fuel in there and you're good. When it gets there, it sucks air instead ...
RwP
09-12-2013, 12:53 AM
15.65 @ 87.3 MPH
Car takes roughly around 45L(11.8 Gal) from empty. When I refill after this issue, it only takes ~27L, but that's after putting in roughly 5-10L to get it to start again.
Also I suppose that could also be the problem. I have a few other things to take care of before I tackle this pain in this ass issue.
09-12-2013, 02:25 AM
The tank is roughly 13.3 gal.
09-12-2013, 09:21 AM
15.65 @ 87.3 MPH
Yeah, but assuming that you actually make it to a gas station when the fuel light is on, there's going to be some gas in the tank. Plus I usually stop pumping when the gas station pump cuts off the first time or to the nearest dollar. The gas pump won't know exactly when your tank is full. I think it relies on pressure or something. Not too sure.
09-12-2013, 03:32 PM
Actually, it's around 14.1. At least that's what it said for my 03 Grand Am. I doubt they used different tanks on both cars.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
09-12-2013, 07:44 PM
The 03 and 04 are 14.1 gallons but the earlier models are a bit smaller I do believe.
2004 Alero 2.2L Ecotec 4 Speed Auto
09-12-2013, 08:45 PM
all the others are bigger...iirc 1999 was 15 and 2000 to 2002 were 14.3
09-13-2013, 06:51 AM
Go borrow a fuel pressure gauge and check ur pressure when this happens.
09-13-2013, 08:53 PM
15.65 @ 87.3 MPH
I probably should. The idea did occur to me but they don't rent em anywhere around here. Atleast I don't know of anywhere. I might just buy one for $60.
09-13-2013, 08:54 PM
Buy one, get readings then return it.
09-13-2013, 09:02 PM
15.65 @ 87.3 MPH
I thought of this, but as a brown man I think this would be too stereotypical and I would just hate myself for it LOL. But I have done it before.
09-13-2013, 09:53 PM
toss it on kijiji for $75 after you use it  profitz for the build!!
09-13-2013, 10:08 PM
15.65 @ 87.3 MPH
Lol genius idea there Tim!
09-25-2013, 11:41 PM
15.65 @ 87.3 MPH
A little update... I haven't gotten around to getting a fuel pressure gauge, but today when I was merging onto the highway I went WOT because I was doing some data logging when all of a sudden the RPMs begin to surge and the car suddenly dies while I'm in motion on the highway. I kept my cool, put her in neutral and coasted with my hazards on until I could safely pull over. After pulled over, I tried starting her because I has just under 1/2 of a tank and after a tiny bit of cranking she fired right up and I cautiously drove to the nearest gas station. Filled up and did some more WOT pulls and she drives fine... It was pretty damn scary... I thought I just had some really bad Knock retard until the battery light came on and I knew that the car shut off and I was pretty screwed.
Next thing to do is definitely get a fuel gauge. I'm not gonna waste any more time trying to guess what the problem is and I don't want to just buy a pump and blindly replace it without getting my facts straight.
09-26-2013, 02:11 AM
Whew, that would be about it for me, I'd get a pump assembly and install it, since they come with a new sending unit and all. Some kits have an upgraded wire harness as well.
09-26-2013, 07:52 AM
15.65 @ 87.3 MPH
Hmm.... Any fuel pump in particular that you recommend? I'm doing a decent build quite soon which may benefit from a performance pump.
