Originally Posted by 01OhioAlero
Pics would be nice, I have made worse things happen.
And MMGT that says its for Grand Am's and mines for Aleros, are you sure? I can I guess feel gains if I get some.
[IMG]
![](http://i64.photobucket.com/albums/h174/foxdemon227garnetdawn/IMG_20140318_180029_zps477aac74.jpg)
[/IMG]
first remove your wheel next your gotta pull the plastic rivets out their are mor then likely going to break, you can do what i did and just put back into place with a couple screws( i spray painted them black afterwards...they got replaced with original fittings when i had it at the body shop.
[IMG]
![](http://i64.photobucket.com/albums/h174/foxdemon227garnetdawn/IMG_20140318_180603_zps3a653572.jpg)
[/IMG]
Remove your battery .Next your going to unbolt the factory air box take the upper half off first which allows to reach the screws 3 or 4 of them if i remember correct..Do not be afraid to man handle the damn thing because the factory tubing are just slide into one another. Then reaching up under the wheel well take out the rest of the factory tubing ..you may not able to get the last part of it out which is okay since its getting air from that and from the air duct beside the fog lamp(if you have them)
I recommend taking the tubing and running it through the hole in the frame first then clamping the filter on.
[IMG]
![](http://i64.photobucket.com/albums/h174/foxdemon227garnetdawn/IMG_20140318_181925_zps159cd509.jpg)
[/IMG]
May take a little adjusting to make it call fit to your MAF sensor after you have everything clamped on your set to go screw in the plastic cover piece and wheel and obviously battery and your set.... upon installing mine I notcied a huge increase in throttle response and a fair increase of acceleration speed between 30 and 70 mph and the awesome sound of the engine when you open her up. Yea i should probably remove the filter and clean it or replace it its been on for about 8 months
[IMG][url=http://s64.photobucket.com/user/foxdemon227garnetdawn/media/IMG_20140318_180048_zps8b3c2132.jpg.html]
And theirs the finished product
![](http://i64.photobucket.com/albums/h174/foxdemon227garnetdawn/IMG_20140318_181906_zpscbe6ebcb.jpg)
