09-21-2014, 12:40 PM
Power Door Issue
I was searching through the forums for a while and couldn't find an answer. My power locks are able to unlock the doors, but I can't lock them.
When I start driving the car, I hear the noise that it makes when you lock the car with a remote (horn noise).
Does anyone know what this could be?
09-21-2014, 05:59 PM
Sounds like a short. Possibly to ground because of the horn wanting to work. All the window switch is is a sensor to the bcm to tell it to work the window.
09-22-2014, 12:22 AM
Is it all doors or just one door? I had one door quit and it was the solenoid.
2000 Chevrolet Malibu LS
09-22-2014, 07:26 AM
All the doors.
09-22-2014, 07:41 AM
Since it's all the doors it's probably the master switch in the drivers door panel. All the windows run through that switch. I would hate to think your bcm is going bad.
09-22-2014, 08:31 AM
Probably a wiring issue.... when i swapped the doors in my van i had to tap am alternate power source as the fuse was not wired up in my fuse panel as it wasn't an option ordered originally on that model....
![](image.php?u=4128&type=sigpic&dateline=1398186297)
09-22-2014, 11:39 AM
It's my doors that came with the car lol. I'll check the voltage at the fuse
11-24-2014, 07:43 AM
Had a similar issue as I bought the car. I replaced the relays of the power door locks and then it worked absolutely fine. Its worth a try before you start to change more expensive parts like bcm.
99 Alero GLS
92 Chevrolet Caprice Classic
11-24-2014, 08:02 AM
I would start with your master switch... thats weird though.
