04-20-2005, 02:47 PM
i origianlly was going to have tires plus install my new pulley but when they saw it they decided not to since its a "race pulley" and is does not have a harmonic balancer like the stocker. my question is will someone in the Grand Forks north dakota area be willing to help me install this? i dont have any tools here at school with me and am not super knowledgable about this install. i will be willing to pay for time or whatever you think is fair, otherwise id be totally willing to bring the beers. so if there is someone in the area that would be willing and able to help me could i drive to you so i could get some assistance in getting this thing installed? thanks in advance. Johnny Boy i know you are here but im not sure if youve got the stuff to do it. if you do let me know.
04-20-2005, 03:33 PM
hey man, call up tintmasters @ 701-780-8895, talk to troy. They are all great guys and are pretty cheap. i would help you but I'm not sure when the next time I will be in grand forks will be. I hope that helps.
04-20-2005, 04:01 PM
i called tintmasters, they are great guys, they are the ones that referred me to tires plus cause they didnt have the right tools. if you could help and had time i would be willing to drive to you but whatever i will figure something out.
04-20-2005, 04:24 PM
the right tools???? seriously, if they dont have a 15mm socket and a pulley puller, then i have no idea why they are in business.
if your coming to the minneapolis area, i would be willing to put it on for you, it takes a whole 10mins......
jack up passenger side
remove wheel
remove/move splash gaurds
remove 15mm bolt from pulley
remove belt
use 3 bolt pulley puller and remove pulley
tap out crank sensor ring
install ring on FFP Pulley using loctite on the screws
put FFP Pulley on the crank and gently tap it onto the crank to seat it
insert 15mm bolt and tighten to spec
replace belt
re install splash guard and wheel
lower car
04-20-2005, 07:21 PM
dude germ would next friday work? i am coming home that thursday night and would be in the area. shoot me a pm plz, your help would be much appreciated.
04-21-2005, 12:01 AM
aparrently for our aleros you have to lower the passenger side engine mount to gain full access to the pulley. i loked at it last weekend, and couldnt even fit my rattle gun in there.
AUTOBOT
04-21-2005, 11:18 AM
i can look at it, but i wont promise anything
i work on friday, so after work would be best
04-21-2005, 11:49 AM
just to be clear i am talking about friday the 29th. but yeah that would work great. ill pm you my phone # and we can work out the details, thank you much dude, i appreciate it.
04-21-2005, 04:03 PM
if you want you could call me to get info, i got a general idea of how to do it. that is if germ is too busy
AUTOBOT
04-21-2005, 05:22 PM
alero i appreciate the offer but i need the tools to be able to do it. i have them at home but my dad wouldnt appreciate me doing something like that to my car. but yeah, if i found the right tools and area here at school i would do it. thanks tho.
04-26-2005, 11:34 AM
i got your PM, and yes, i am talkking about this coming weekend.
like i said, i will look at it. i dont think it will be an issue to put it on.
keep in mind that you MIGHT need a case learn done and an SES light might be set, but im sure you know about that already.
04-26-2005, 12:34 PM
can u explain what a case learn is
Pheenz Motorsports Founder
04-26-2005, 12:39 PM
so then you will call friday? sorry im just tryin to get plans finalized. pm me with the final plans or post em up and let me know what im gonna need like just the pulley or the belt needed and that type of stuff. thanks again for the help.
04-28-2005, 02:35 PM
yea, i will call you on friday.
i get out of work around 3:30 pm or so, so it should be right around that time.
however, im not 100% positive that we will be able to do it friday, im pretty sure we can tackle it, but just incase, you are going to be in town all weekend right?
i have all weekend off from work just, so just in case friday is a no go, then saturday or sunday is ok with me if its ok with you.
