Old 05-05-2005, 11:21 AM   #1
2001alerogl
i have a 2001 alero 2.4L tried to use my cruise control after not useing it for a long time .
it doesnt seem to ingage the light doesnt stay on unless you keep it pushed in.
i am guessing that it is the switch but other than that i dont know .
if anyone knows what it might be could you let me know
Old 05-05-2005, 11:43 AM   #2
jamcllw
I voted for the switch
Old 05-05-2005, 12:18 PM   #3
I said switch too, but mine seems to not work after using it for a long time. I drove to NC a couple weeks ago and somewhere in NC towards the end of the trip, it just didn't want to work for me...it worked the next day tho
Old 05-05-2005, 12:22 PM   #4
j-work
Senior Member
j-work is an unknown quantity at this point
Mine has seemed to work fine all of the time. I also have a 2001 2.4L.
j-work is offline   Reply With Quote
Old 05-05-2005, 12:51 PM   #5
|Rev|
prob the switch
Old 05-05-2005, 12:53 PM   #6
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I had a 2000 also with the 2.4 and the cruise control always seemed to work for me.
Old 05-05-2005, 01:22 PM   #7
smlzalero
where my knickers at?
smlzalero's Avatar
smlzalero is an unknown quantity at this point
I have an 01 2.4, never had any problems with the cruise, it's probably the switch, try swapping it out.
--UPDATE-- $88,000 in debt.
smlzalero is offline   Reply With Quote
Old 05-05-2005, 03:08 PM   #8
j_smith
Mine did the same exact thing. Replaced the switch and it works fine now.
Old 05-06-2005, 10:40 AM   #9
neuroplasma
Mine is doing the exact same thing. How do you change out the switch?
Old 05-08-2005, 12:22 PM   #10
black99alero
black99alero is an unknown quantity at this point
Yea...........Mine hasnt worked for like 3 years, the only way it will work if you hold the cruise switch down the whole drive..........How would one go about replacing the switch?
<!-- Copied from MySpace.com -->
&lt;a href=&quot;http://www.myspace.com/michigancowgirl201&quot;&gt;Find me on MySpace and be my friend!&lt;/a&gt;
black99alero is offline   Reply With Quote
Old 05-08-2005, 10:37 PM   #11
TwistedDreams
VIP
TwistedDreams's Avatar
TwistedDreams is an unknown quantity at this point
Send a message via AIM to TwistedDreams
mine has never worked matter of fact I tried getting it to work today but no luck light comes on but yet nothin but deceleration
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
TwistedDreams is offline   Reply With Quote
Old 05-12-2005, 02:20 AM   #12
1WhiteOSV
check the cable on the throttle body....
Old 08-29-2005, 12:27 PM   #13
geedog66
yeah im having the problem where the light works all the switches work.. it even will turn the cruise light when i hit the brake but it will not engage any help???
Old 08-29-2005, 03:22 PM   #14
bigd6983
im having a similar problem.......it use to work, now it just seems like the switch wont stay pushed in.......if i hold it in the led lights up, ive never tested to see if it works that way........but id assume its just the switch
Old 08-30-2005, 10:09 PM   #15
stealthlero
stealthlero is an unknown quantity at this point
Send a message via MSN to stealthlero
i had this problem not too long after i got my car, but instead of spending money and buying a new switch, just take a coin, (penny or dimes even more thin) and hold the on/off button in, and wedge the coin in there, if you wedge it in there good enough, it should stay on and it'll never come out unless you pry it out yourself... hope this helps you guys!
stealthlero is offline   Reply With Quote
Old 08-31-2005, 07:56 AM   #16
geedog66
i have no problem with the switch the light stays on no problem
Old 08-31-2005, 10:40 AM   #17
alerochick242
Did you check the fuse? I'm pretty sure there is a fuse for the cruise control.
Old 08-31-2005, 11:40 PM   #18
stealthlero
mine wasnt a problem with something in the computer engaging it, mine was the cruise button never stayed clicked on whenever i pushed it, so i just have it stuck on now..... easy $ .10 mod
Old 02-26-2006, 12:52 PM   #19
Hotel Kilo
I just got this problem too. I have a '99 3.4L and i use the cruise control all the time since i got a speeding ticket this helps me stay at the right speed. It used to take a few clicks to get it to stay in place but now it wont stay at all and its getting annoying. Anyone know how to take the switch apart or at least a simple way to fix it?
Old 02-26-2006, 01:11 PM   #20
Lovestheh20
jam a piece of paper in the on/off switch, it will keep it engauged.. its what I've done for the past 5 months. works great.
