Old 05-08-2005, 09:20 AM   #1
glowbot
I am all ready to start on my engine work now, buying the RSM s/c but am unsure what PSI I should run and what I would need to upgrade in order to run 8 or 12 PSI. As of right now I have ported headers, ported upper and lower intake manifold, 62mm TB, and 2.5 inch free flowing exhaust with a dump off.
I was also wondering how much we can bore out our engines and what kind of power I would be looking at if I did it? One of my mech buddies said prob around 40 HP but hes not do anything like that to a 3400 SFI before.
Old 05-08-2005, 09:30 AM   #2
SilverBullet256
Senior Member
SilverBullet256 is an unknown quantity at this point
Send a message via MSN to SilverBullet256
hmmmmm, if i remember correxctly you cant bore these engines out very much at all, so i dont think you can get 40 hp from them, i think oldsmans is slightly bored,(has the 2.4 though) but still didnt see gains like 40, thats alot, we dont even make a hp per cubic inch in fact we make about .81 hp per cubic inch and so to get about 40 more hp out of the engine you would need to bore roughly 50 cubic inches over stock, and i dont think our block can bore that much, now if you add all of the ported things and stuff, like if you had all of the parts like redog then he is probbaly pushing around if not more then 1 hp per cubic inch, which is a very rare thing nowdays without using forced induction
SilverBullet256 is offline   Reply With Quote
Old 05-08-2005, 12:43 PM   #3
bigd6983
yea it is rare, these little preludes, rsx type s's, the new civic si's all have over 1 hp per cubic inch without boost, and the new hemi at 6.1 litre's is suppose to have 425 hp so its right there.......
it seems like hes taken all the right steps........id say get an adjustable fpr, and that will let you run the 8psi without worrying too much, but once you get into that 12 psi range im sure you will start having troubles, if not with engine internals and the bottom end, with the tranny.........
Old 05-08-2005, 02:29 PM   #4
glowbot
Well they make 12 PSI for the 3400 SFI so I know it can be done was just wondering what needed to be upgraded to do it. My goal is to get my 3400 pushing 400 HP or more by the end of the month. I can have the engine bored out for 500.00 and I was looking at getting the stroke increased at the same time as all the other work but it would cost a rather large sum of money and Im not sure its been done on the 3400 yet.
Old 05-08-2005, 09:17 PM   #5
SilverBullet256
Senior Member
i meant rare for gm :P , only a few good cars push out 1 hp per square inch in the gm lineup like the LS engines, those push out almost exactly 1 per square inch, so yeah i was wrong but right, just not clear on what i said
Old 05-08-2005, 09:18 PM   #6
SilverBullet256
Senior Member
if you are really looking to push 400 hp then i would definately talk to john(springsfastestalero) he would be the main person that could push you in the right direction
Old 05-08-2005, 09:40 PM   #7
glowbot
Thanks. I will post some pics and let you guys know how things are going.
Old 05-08-2005, 09:47 PM   #8
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I would just buy the 6psi version, I dont think you will have the need to do any other engine mods.
Old 05-08-2005, 11:53 PM   #9
ryanthefizz
ryanthefizz's Avatar
ryanthefizz is an unknown quantity at this point
ya, someone said you can only bore like 1/16 of an inch or some tiny number, not worth it i believe.
ryanthefizz is offline   Reply With Quote
Old 05-09-2005, 12:35 AM   #10
bigd6983
yea i dont think its worth it either, not for the cost of boring it out i dont think and the time it takes to get the part out........
lol my bad silverbullet, yea as far as gm it seems only the ls engines are up there........
Old 05-09-2005, 05:07 PM   #11
-Alero-
-Alero-'s Avatar
uou wont be able to touch 300 hp without doing something with your tranny
AUTOBOT
Old 05-09-2005, 05:15 PM   #12
Travis99Alero
400 hp? are u joking? i dont even think you can get there by the end of the year, let alone by the end of the month.
Old 05-09-2005, 05:44 PM   #13
Blackrider
bored out what .060 wicth will give you a total displacment of 34500C??? Go for it.
Old 05-09-2005, 06:54 PM   #14
Originally posted by -Alero-+May 9 2005, 03:07 PM--><div class='quotetop'>QUOTE(-Alero- @ May 9 2005, 03:07 PM)</div><div class='quotemain'><!--QuoteBegin-glowbot@May 8 2005, 09:40 PM
Thanks.Â;-) I will post some pics and let you guys know how things are going.
[/b][/quote]
exactly, especially not with that puny rsm supercharger..........i've seen John's setup and talk to him all the time.........trust me......you will need a lot of work to hit 400................a f***en poopload of work........
Old 05-09-2005, 07:13 PM   #15
SilverBullet256
Senior Member
john has been investing a ton of money work and time into his car to reach 500, but you still need to put almost just as much of everything to even be able to reach 400
&quot;you walk around with a dodge symbol on your crotch all day and when girls look you say, &quot;yeah, It's Got a Hemi&quot;
Old 05-09-2005, 07:38 PM   #16
yep, horsepower out of an engine is an exponential thing.........it takes more money for less and less horsepower the farther you go.......
Old 05-09-2005, 11:13 PM   #17
germ
are you guys talking 400 crank or wheel hp?
400 crank is very attainable (320 wheel hp)
400 wheel hp, well, thats a totally different story, thats 500 crank and envolves a whole lot.
Old 05-09-2005, 11:36 PM   #18
when i talk hp i always talk wheel horsepower because that is all that matters.......
Old 05-10-2005, 09:18 AM   #19
germ
thats all that matters?
umm kay
ill leave that one alone.
Old 05-10-2005, 05:52 PM   #20
Alerosince99
Having 400-500 whp doesnt mean diddlely squat if that power doesnt meet the street.
