Old 07-10-2005, 04:09 PM   #1
black99alero
black99alero is an unknown quantity at this point
Anyone have their water pump go bad? If so........what were the symptoms that your car had?
<!-- Copied from MySpace.com -->
&lt;a href=&quot;http://www.myspace.com/michigancowgirl201&quot;&gt;Find me on MySpace and be my friend!&lt;/a&gt;
black99alero is offline   Reply With Quote
Old 07-10-2005, 04:39 PM   #2
Crolero
Well i think your best bet would be useing the search feature to find answers faster.
But if your water pump is acting up you might be leaking from the pump, your engine will get hot faster. gl
Old 07-10-2005, 05:06 PM   #3
AftermathAlero
on my 3400 engine.. it was coolant was sprayed under the hood from it leaking out of the side of the water pump onto the belt and slinging onto the hood. And coolant bottle being empty real quick too.
Old 07-10-2005, 05:58 PM   #4
King Asoka
King Asoka's Avatar
^, ya I had the same symptoms. pretty cheap to replace. and I recommend that you flush your cooling system and replace the dexcool with the green stuff.
Old 07-10-2005, 07:41 PM   #5
sound_xtreme
sound_xtreme's Avatar
ditto, coming from the weep hole
Cardomain
Old 07-10-2005, 09:29 PM   #6
black99alero
Well my low coolant light came on way back in the winter, so I flushed the radiator and it went off.........the other day is came on again and I checked the reservoir and it was empty, so I filled it up and drove it about 25 miles and it came on again...........once again the reservoir was empty........I have parked it till tomorrow when I can get an appointment to get it looked at........You think maybe it never got to the point where antifreeze was spraying all over? I just hope it dont cost TOO much to fix!!!
Old 07-10-2005, 09:54 PM   #7
jamcllw
If you have a 3.4 then you might have a LIM gasket leaking. Leaking coolant is one of the many symptoms of it.
Old 07-10-2005, 10:03 PM   #8
black99alero
I have the 2.4
Old 07-11-2005, 11:45 AM   #9
black99alero
Well guys.........I just got the call from the dealer and it was the waterpump and its gonna cost me right around $900 to fix!!Thank god I had a empty credit card laying around!!!
Old 07-11-2005, 01:36 PM   #10
King Asoka
King Asoka's Avatar
dood!!!!1
take it some where else
$900 is way too much
a new pump is like $150CDN.....and the labour is like an hour or two. Dont let them fix it for that much! Total rip!
did a little reseach and you can get a water pump for the 2.4L for way less than $150.....
Old 07-11-2005, 02:36 PM   #11
black99alero
Too late They are already half way done..........I have been ripped off before by mechanics I can take it again I guess.............
Old 07-11-2005, 02:49 PM   #12
King Asoka
King Asoka's Avatar
dam dood, im sorry I couldnt have told you sooner.
I really suggest that whenever you get work done on your car do a little reseach. It only takes a little time and can really pay off in the end.
Hope you dont get screwed again.......
