Old 08-17-2005, 09:32 PM   #1
dlbsalero
Sometimes my 99 Alero (3.4L) won't crank for upto 10 minutes. Security light will flash. Can this be a bad key (is there a chip in this original key)? Will the BCM (Body Control Module) give a code for this intermittent problem? Could it be the ignition switch going bad? Anybody had a similar problem?
Thanks for any suggestions.
Old 08-17-2005, 10:31 PM   #2
There is no chip in the key, The passlock system is in the igntion lock cyl.
The cyl might not be bad, Your car is 6 years old, are you still useing the origanl key? Keys wear down over time, try a new freshly cut key.
I had the same problem, a newly cut key fixed it right up
Old 08-18-2005, 11:17 AM   #3
dlbsalero
Thanks for the reply. I will try a new key when I get the car back this weekend.
Hope this is the problem.
Old 08-24-2005, 09:40 PM   #4
pimpnalero99
check out your owners manual too. my '99 did that before and there is a section in there about passlock and how to bypass it. i think u turn your engine to the on position, keep ur foot on the brake and switch into every gear, then turn it off and try and start it. something similiar to that. just check out ur owners manual.
Old 08-24-2005, 09:42 PM   #5
jackal2000
jackal2000's Avatar
i had the same problem with my 2000....it threw two codes, both of which for the cyl. $350 later its fixed
Old 08-24-2005, 11:32 PM   #6
Oldsman
Owner
Oldsman's Avatar
that is something like i did with mine when my 99 did that crazy poop.
what a pain in the ass. but got it to work.
Beware of the BackStabber
Old 08-25-2005, 01:32 AM   #7
AftermathAlero
just bypass it with a resistor after u cut the yellow passlock resistance sensing wire. passlock sucks anyways... its not gonna stop anyone from taking the car.
Old 08-25-2005, 01:38 AM   #8
Whitetigerboi83
Whitetigerboi83's Avatar
Whitetigerboi83 is an unknown quantity at this point
Send a message via AIM to Whitetigerboi83 Send a message via MSN to Whitetigerboi83 Send a message via Yahoo to Whitetigerboi83
well it will slow them down a bit cant really start the car for 10 min .. but i guess if thery really want it they take it... thats why i like my bypass kit i got fron jcwhitney with my new alarm... took a few to figure out the actual resistance a digital voltmeter helped get the right settings..
Whitetigerboi83 is offline   Reply With Quote
Old 08-25-2005, 02:23 AM   #9
AftermathAlero
lol.. wasted ur money on the bypass kit. a resistor at radio shack like 10 cents. or bypass kit for like 15 bucks. hehe
