Old 03-18-2006, 11:20 AM   #1
Str33tRacer
lights
this 2112 bulb should work for my dome right? but i want to replace my floor, rear view mirror, and dome lights, so what did other people do, i cant seem to find a blue replacement bulb
Old 03-18-2006, 11:38 AM   #2
stealthlero
stealthlero is an unknown quantity at this point
Send a message via MSN to stealthlero
here's where I got most of my interior bulbs, bright bulbs and relitively decent prices...
http://www.autolumination.com/
stealthlero is offline   Reply With Quote
Old 03-18-2006, 12:15 PM   #3
Str33tRacer
these are the bulbs i want to replace but have NO idea how to do this.... at napa its a single unit with the plastic on it you have to buy they said u cant just switch the bulbs... how do u replace these??
Old 03-18-2006, 12:38 PM   #4
stealthlero
i think they are just normal 194 bulbs, like the ones down by your feet, and you just have to take the normal bulbs out of the plastic piece and solder the new bulbs into that and that should work
Old 03-18-2006, 01:06 PM   #5
Str33tRacer
what about the mirror lamps, are those just under the plastic piece, will that pop right off?
Old 03-18-2006, 01:33 PM   #6
stealthlero
yup, the bulbs are just held in with a couple metal clips, just pull them out and pop the new ones right in
Old 03-18-2006, 02:24 PM   #7
jonez
Those are 194 bulbs and are very easy to replace. Anywhere that sells bulbs will have 194 bulbs
Old 03-18-2006, 02:32 PM   #8
I just pop my 194 bulbs out and put the new ones in.... Do I have to sodder them in????? I never did....
Old 03-18-2006, 03:34 PM   #9
jonez
nope, just pop out and replace
Old 03-18-2006, 04:21 PM   #10
Str33tRacer
i cant get the damn bulbs outta that blue plastic!!
Old 03-19-2006, 12:52 PM   #11
Str33tRacer
after looking at it, i dont think these are supposed to come outta the plastic
Old 03-19-2006, 01:16 PM   #12
stealthlero
as far as i know, thats the only way that the lights will work once you put them back in, you need the blue plastic, im not 100% sure but thats what a buddy of mine had to do when he did his dome lights
Old 03-19-2006, 05:41 PM   #13
cruisinalero
cruisinalero is an unknown quantity at this point
yes it can be done...the wires coming from the existing bulb have to be broken off the blue plastic...then just bend the new leads off the new bulbs and what i did was just soldered them into place...
cruisinalero is offline   Reply With Quote
Old 03-21-2006, 02:10 AM   #14
If you go to AutoZone, they have separate holders in the electrical section that you can buy and just put 194 bulbs in.
Old 03-21-2006, 10:03 AM   #15
02_Silver_Ho
02_Silver_Ho's Avatar
02_Silver_Ho is an unknown quantity at this point
Sorry to jack your thread Str33tRacer , but am I the only one here that doesn't have floor courtesy lamps? This must be a year to year thing, I have an 02 GL V6.
02_Silver_Ho is offline   Reply With Quote
Old 03-21-2006, 10:07 AM   #16
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
you should have them then.
take a look under your dash to your left. there should be a bracket thats in a small hole you can twist and remove, maybe you have dead bulbs?
Old 03-21-2006, 10:16 AM   #17
02_Silver_Ho
I looked when I swapped all my other interior bulbs for LED bulbs, but maybe not hard enough. I'll look after work, not like I really need them because the LED bulbs in the dome and RV mirror are so damn bright already..Thanks
Old 03-21-2006, 11:29 AM   #18
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
yeah i don't seem to have floor curtosy lights as well..... i have a 2001. i'm going to check that out tonight as well....
battistoni21 is offline   Reply With Quote
Old 03-21-2006, 11:50 AM   #19
i definitely don't have floor courtesy lights...
apparently the maker of the car was too cheap to pay for that package.
Old 03-21-2006, 12:19 PM   #20
02_Silver_Ho
Just a hunch, but aren't there some people out there with aleros that don't have the rear view mirror map lights? If that were the case, maybe some aleros come with only dome and map lights (like mine), while others come with dome and courtesy (no map lights). The only reason I think of this is that when I look at new car stickers at a dealer or something, I often see things such as maplights and courtesy lights mentioned in the details....Or maybe I'm just overworked today..I need a beer
