Old 08-10-2007, 12:36 AM   #1
sorrowfulkiller
sorrowfulkiller is on a distinguished road
Send a message via AIM to sorrowfulkiller Send a message via MSN to sorrowfulkiller Send a message via Yahoo to sorrowfulkiller
Ways of putting LEDS in map pockets and vents
I've been tossing around the idea of putting in some leds in my car for a month or so, I already have underdash neons (which I'll be changing out for $25 neon kit that illuminats the back too) but I wanted to add some some more, like in the center console, in map pockets and in the vents, and also in a cubby hole I have under my head unit.
Justing trying to figure the easiest way to do it... I was thinking of attaching them with epoxy but idk how I would put them in the vents and in the map pockets
Live for something or Die for nothing
sorrowfulkiller is offline   Reply With Quote
Old 08-10-2007, 12:59 AM   #2
Drill a hole, epoxy, basically any way you want.
As long as it holds.. no one is supposed to see the LED so it can be ugly.
Old 08-10-2007, 10:02 AM   #3
there is a how to for the vents and doors..
if its a standard LED... sand the tip flat, and use a 13/64ths drill bit. the led fits through, but not the bigger lip around the base.
Old 08-10-2007, 03:42 PM   #4
Cyber Knight
Swank
Cyber Knight's Avatar
Here's how I did my vents on my current car. They are similar enough to the Alero vents (I did it to those also when I had it).
http://www.oznium.com/forum/topic13867
Old 08-10-2007, 08:51 PM   #5
sorrowfulkiller
Well I don't have an alero anymore... so either way its alright. I'm just trying to think now how the heck I'm going to do the side vents. Oh well I'll figure something out, I'll have to check out how the dash sits underneath a couple of the vents. Thanks for the help everyone.
Old 08-10-2007, 11:29 PM   #6
Vents: http://www.aleromod.com/forums/showthread.php?t=5350
Mine are done similar to Cybers. I just encased then in a cube of hot glue... its really not necessary. you can just bend the leds at a right angle and point them out the front, and drill a small hole underneath to run the wires. But i would put a small bead of silicone or hot glue on metal contacts... to prevent moisture/corrosion. (i have 1 on drivers side vent, 2 in each side of the center vent and 2 in the passanger vent) 4 in the pic, cuz i have reds and blues set up... two complete different circuits.
Doors: http://www.aleromod.com/forums/showthread.php?t=8297
Little trickier, but easy to do... just takes a little time.
