06-12-2009, 01:35 AM
Heres another one. I have heard some bad things about doing business with them though.
http://www.z-spec.com/catalog.htm
06-12-2009, 01:40 AM
Canada's Ghost
Originally Posted by Valley olds
cool Z-Spec is cheaper
06-15-2009, 02:47 PM
The Aleromod PITA
is the benefit of the increased bore just better airflow?
06-15-2009, 02:54 PM
Yup, just more air, especially if the intake manifold is ported.
06-15-2009, 04:42 PM
The Aleromod PITA
could you pm me and explain that a little more in depth
06-15-2009, 04:51 PM
what more indepth do you need? air in = air out. Unless your air passage through the engine can't take any more air, due to room restraints. You port your intakes, you have more room for more air.
06-15-2009, 07:23 PM
The Aleromod PITA
dont worry about it, Valley was kind enough to explain it to me, im learning
06-16-2009, 01:16 AM
ive already picked up a ported intake manifold but i need to get a TB and CAI or WAI intake not sure which though.
06-16-2009, 04:26 AM
ummm... i might be wrong... but here's what i've learned from reading the forums
for normal street driving... the WAI is what you want... very little chance of your engine sucking up water and other stuff...
and if your going to S.I.R. well add a couple more pipes and convert your WAI into a CAI.
That is probably best case scenario. I have a k&n drop in filter... but soon a WAI. If i got a ported manifold and a bigger throttle body... it probably wouldn't help much with a drop in filter.
06-16-2009, 11:41 AM
WAI for a little more power and better fuel economy, CAI for more power than the WAI, but worse fuel economy. At least thats what Ive read in the forums.
06-16-2009, 06:11 PM
damn is there a way to have both haha. better fuel economy sounds good but so does more power
06-16-2009, 06:45 PM
with the right tubing, you could convert one to the other, easily. (mount the CAI and leave it in the fender)
other then that, no, its not possible. Your car would always have a WAI if you installed both, simultaneously.
06-16-2009, 06:56 PM
damn haha oh well id probably just go with a WAI and make a custom heat sheild and figure out the best way to get the coldest air
06-16-2009, 07:09 PM
06-16-2009, 08:10 PM
The Aleromod PITA
seth i left the piping from my stock air duct in as much as i could to direct the cold air it brings to my engine compartment towards the filter
