Old 03-20-2007, 09:59 AM   #1
Mr_Reed
Mr_Reed's Avatar
Mr_Reed is on a distinguished road
Send a message via AIM to Mr_Reed
Alarm Problem??
Well I'm a little pissed off and disapointed in my Alero..
As of right now..
My Windows don't roll down.
My Lower Intake Manifold Gasket has a small leak.
My Fog lights don't work.
My Turn Signals have a mind of their own..
And now my newest entry is that my Alarm on my car is being retarded. I'm not sure whats setting it off but all I know is that it shuts off the fuel to my motor when its triggered I half to put the Key in the ignition for 10 minutes until the security light goes out than it will start but I'm getting tired of doing that anyone else ever had a problem with their Alarm?
Live to Ride
Ride to Die
Mr_Reed is offline   Reply With Quote
Old 03-20-2007, 11:15 AM   #2
alero168
I Love Tiara!
alero168's Avatar
alero168 is an unknown quantity at this point
Send a message via AIM to alero168
if youre talking about the passlock then you might need a new key cut, take it to a locksmith too not walmart
alero168 is offline   Reply With Quote
Old 03-20-2007, 11:19 AM   #3
AGT
AGT's Avatar
As of right now..
Fogs-Did you check the bulbs yet?
Alarm-Do you ever turn your car to the ON position and then turn it back before you start it...I just ask because I used to and the security light would come on. Only way for it to go off way to tunr off and back on
Old 03-20-2007, 11:35 AM   #4
Mr_Reed
Mr_Reed's Avatar
Yes, the assembly messed up I need to replace the hole light..Its all good though.
Yeah but if I do that and than turn the car off and back on the car won't start.
I half to wait 10 minutes the the key on than when the light goes off it will start.
Live to Ride
Ride to Die
Old 03-23-2007, 06:29 PM   #5
alero168
I Love Tiara!
alero168's Avatar
you need to cut a new key
Old 03-23-2007, 06:52 PM   #6
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
Can you just get a new key cut? I though you had to replace the whole ignition.
steve-o is offline   Reply With Quote
Old 03-23-2007, 07:08 PM   #7
the thing that is causing your signals acting up is the hazard light switch (red button with a triangle in your dash) if you wiggle the button around with your turn signals on you will see what i mean, just put it into a place where it doesnt act up, or just get the hazard switch replaced
Old 03-27-2007, 11:16 AM   #8
alero168
I Love Tiara!
alero168's Avatar
not new key as in a different set of keys but just freshly cut of your original keys... this topic has been talked about before, a search should pull up what i'm talking about.
