Old 12-07-2007, 11:08 PM   #1
silverbullet81
silverbullet81 is on a distinguished road
Unhappy lights on
ok i thought i had read this on here somewhere before but now i can't find it and im really tired so im just going to ask. what does it mean when the service vehicle soon, anti-lock, and trac off lights all come on. tonight was the first time we have had snow here and when i got out of work and was driving home i was sliding a little on the roads and then all of a sudden those lights all came on. what could be the problem and how do i fix it?
silverbullet81 is offline   Reply With Quote
Old 12-07-2007, 11:10 PM   #2
Vinalero
Vinalero's Avatar
Wheel hub assembly
Old 12-07-2007, 11:12 PM   #3
silverbullet81
Originally Posted by Vinalero View Post
Wheel hub assembly
how hard is that to do and is it alot of money?? and how important is it? like is it bad to just keep driving it the way it it?
Old 12-08-2007, 12:03 AM   #4
freakout
freakout's Avatar
freakout is an unknown quantity at this point
It's the sensor for the abs, but the hub is a sealed unit. You have to replace the whole assembly. You can drive it but you have no abs. Pretty sure there is a how-to on replacing it. Not that hard. You might want to go over the electrical connections. You said it was the first snow. Maybe the connection got messed up.
freakout is offline   Reply With Quote
Old 12-08-2007, 01:01 AM   #5
Vinalero
Vinalero's Avatar
Not that hard to swap, you should be able to run on it for a while, but not forever. If its only the sensor, well you are ok, but generally the hubs goes as well.
Old 12-08-2007, 08:51 AM   #6
silverbullet81
is there any way to tell which one is the bad one?
Old 12-08-2007, 08:55 AM   #7
if you drive on it for too long and the bearing ceases up you could crash your car.
Old 12-08-2007, 05:50 PM   #8
Jferg2223
Jferg2223's Avatar
Jferg2223 is on a distinguished road
mine did the same thing when i locked up my e brake and started burning my tires but they went off after i shut the car off and turned it back on
3400 V6
MSD Coils - NGK Iridium Plugs - Taylor Wires - 62mm RSM Throttle Body - DHP PCM- 180 Stat - TPS Enhancer - Custom 3" CAI - Thunderbolt Spin Cat no resonator - Dynomax Dual exhaust w/ Borla Tips- Cleared Corners/Black Bezels
Jferg2223 is offline   Reply With Quote
