05-11-2008, 12:49 AM
Stock Radio SAYS ERROR??
all day my car was doing great. and then I went to a socail and on the way back i started my car and the Red led was on constantly and the deck showed "ERROR" and the time.? any one have a clue?
05-11-2008, 12:53 AM
I think there might be an error??
Sorry, I couldn't resist!!! Personally I have no idea.
05-11-2008, 12:58 AM
WELL DUH BUT im wondering if thiers a reason for such
05-11-2008, 01:12 AM
I dunno what it's tryin to tell you, but I will sell you my stock if you want it
Does your car start normally and everything? Also, what year is it? Don't some of the newer years have a security system that uses the radio for a display?? THese are just ideas. I have a 99 Alero, and have never seen this on the radio, and doubt I will, now that I have an aftermarket radio. I am sure if you wait a bit, SOMEONE will come up with the answer.
P.S. I WAS just kidding with my answer. :-)
05-11-2008, 03:25 PM
car is fine today :S evrything is working like it has. but thats just weird out of no where? its a 2001 coup
05-11-2008, 03:34 PM
I know if you have a 2001 and up, theres a special procedure when installing the radio because theres some kind of anti theft device that works with the radio or something like that and you have to install the stock HU in the back of the car or something in order to be able to start the car. When I had my HU installed, the guy told me I was lucky I had a 2000.
05-11-2008, 03:50 PM
well actully you dont need to install the old one in the car anymore they have wire harnesses with a chime box. i had a touch screen in their befor. sodl my system then someone tried to steal my car and body shop fixed my intier dash and fod light switch and hazard.
05-11-2008, 11:49 PM
It just said ERROR and that's it? It didn't say CAL ERROR?
05-12-2008, 08:26 AM
hmmm..happens again unhook battery for like 20min and then retry
05-12-2008, 10:20 PM
Yes It just said ERROR and the time. and then yestraday i went out for supper and after supper my car was completly dead! nothing what soo ever. poped the hood and wiggled my barrty cable and poof started no problem. soo my guesse is that the autobody shop that took my car in never tighend the post. and since then no problems. but its only been a day.
