09-24-2008, 03:39 PM
Service engine light... could be O2 sensor
Hey guys, i just hit 90k a little while ago and lately (under hard acceleration) the motor stumbles. I checked the servce manual for a diagnosis for the hesitation, and the first thing it listed was O2 sensor replacement. And now, the service engine light just came on last night. I tightened the gas cap just to make sure it wasn't a fluke and it seems that it's not. So have any of you guys had this problem and was it solved with a new O2 sensor? Also, I have the V6.
'99 Alero GLS Sedan - Gold, V6, 17x7 Enkei PK6s,
SLP Catback, Eibach springs
09-24-2008, 03:48 PM
I would say go to Autozone or Advance Auto or one of those parts stores that reads codes for free and see what code it's throwing before jumping to any conclusions.
09-24-2008, 03:57 PM
motion seconded
09-24-2008, 04:06 PM
Either O2 sensor or cam position sensor.
Have a good day
09-24-2008, 04:27 PM
spark plugs (misfiring)
must read code
09-24-2008, 05:36 PM
I wish I had a scanner. If anything, I'll purchase a new O2 sensor and replace the old one and see if that fixes the problem. If it doesn't, then i'll just have my have my mechanic use his to find the problem. But thanks for the help everyone.
09-24-2008, 05:37 PM
this is new to me though that autozone will do it for you. ill try that.
09-24-2008, 05:38 PM
Autozone for a free code read
Nearest Locations  MilesAddress
Location Info 3SW 15300 19 Mile Rd
Clinton Township, MI 48038
(586) 226-8681
Get Map and Hours
Get Directions 4SE 388 N Gratiot Ave
Clinton Township, MI 48036
(586) 468-5295
Get Map and Hours
Get Directions 5E 51301 Gratiot
Chesterfield Twp, MI 48051
(586) 949-7068
Get Map and Hours
Get Directions 5W48940 Van Dyke
Utica, MI 48317
(586) 739-4325
Get Map and Hours
Get Directions 6SE 36727 Gratoit
Clinton Township, MI 48035
(586) 790-8874
Get Map and Hours
Get Directions 10S 28401 Groesbeck Hwy
Roseville, MI 48066
(586) 777-6665
Get Map and Hours
Get Directions 10SW 2702 Metropolitan Parkway
Sterling Heights, MI 48310
(586) 795-0701
Have a good day
09-24-2008, 05:44 PM
how much are o2 sensors?
09-24-2008, 05:50 PM
around $90.
09-24-2008, 06:02 PM
wait you're in MI, get over here I'll scan it with HPTuners
09-24-2008, 06:19 PM
Don't throw money at the problem before you know what it is.
Plus you'll need a scaner to delete the code anyway
09-24-2008, 07:00 PM
Right. I spent $300+ replacing the oxygen sensors, did a complete tune up with plugs and everything, and then it didn't even fix the problem, it was the catalytic convertor.
09-24-2008, 10:05 PM
could be MAF too. Buy buddy had his go on his S10 and it pretty much did the same thing. Whatever u do dont let a shop install it, they will charge a ton and its about the easiest thing to install. Also I bought an OBD2 code reader a few months back and it is the best investment I have ever made, seriously consider getting one.
09-24-2008, 10:48 PM
Well, I had autozone scan it and it turns out that there was a misfire in cylinder #2. Now i just changed the plugs and wires less than a year ago so it can't be that. It has to be the coil, maybe corrosion on the contacts. The guy over at Autozone also said that it could be the injector too, but i'm having a hard time seeing how an injector would cause a misfire.
09-24-2008, 11:10 PM
Not enough fuel mixture
Pull out #2 and look at it, see if it's fouled
09-25-2008, 12:32 AM
If plug #2 is white then it would be a clogged injector meaning lean, if it is fouled as Redog stated then your injector is leaking causing you to run rich, which seems more likely to me as lean normally doesn't misfire like rich will.
09-25-2008, 01:26 AM
Man, that thing still better work when i get it back
09-25-2008, 09:39 AM
Trying to get it together
MODS:???
09-25-2008, 02:08 PM
swwweeeeeet
