Old 10-03-2008, 10:37 AM   #1
CactusWill
No Interior Lighting
I read through a ton of search results but wasn't able to find anything.
All the interior lighting stopped working all at once, this includes the dome light, map lights, and floor lights.
I checked all the fuses, and all of them were good. What else do I need to do here? I'm stumped.
Old 10-03-2008, 11:03 AM   #2
AGT
AGT's Avatar
Including your gauges?
Not one blown fuse? at all? crazy
Have a good day
Old 10-03-2008, 11:06 AM   #3
CactusWill
No, the guage illumination does work. Its all of the courtesy lighting that went out.
Old 10-03-2008, 11:41 AM   #4
its gotta be a fuse, check them again
Old 10-03-2008, 11:53 AM   #5
deathwish666
deathwish666's Avatar
deathwish666 is on a distinguished road
when you figure it out let me know...ive been trying to figure out how to turn them all on/off with a swith haha
00 alero
so far: jvc cd player, sony xplod speakers, jl 1000/1 amp
2 12" kicker cvr, wai, green underglow
coming soon: some led's, better subs
deathwish666 is offline   Reply With Quote
Old 10-03-2008, 11:55 AM   #6
circeansleeper
circeansleeper's Avatar
circeansleeper is on a distinguished road
Completely off topic, Gr1m I can't read what your avatar says...
Annoy a Liberal: Work, Succeed, Be Happy!
circeansleeper is offline   Reply With Quote
Old 10-03-2008, 11:58 AM   #7
AGT
AGT's Avatar
Thread destroyer^
Have a good day
Old 10-03-2008, 01:46 PM   #8
CactusWill
I checked them all twice.
Old 10-03-2008, 02:04 PM   #9
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
I can only guess your tallights still work, otherwise your SVS light would be on and you'd be stuck with the issue I have. And you checked all the fuses? Only thing left is the relays, right?
CiscoPath is offline   Reply With Quote
Old 10-03-2008, 02:27 PM   #10
CactusWill
Yeah everything else is working. Anyone know if the interior lighting goes through a relay?
Old 10-03-2008, 04:17 PM   #11
now back on topic (like anyone will even notice i wrote under that picture)
Check your dimmer switch, since thats kinda the relay for your interior lights, if its blown, it could cause power to not go to anything. Also check to make sure the bolts in the middle of the fuse box are tight. One of mine loosened, once, and it caused shorts all over the place.
Old 10-03-2008, 07:57 PM   #12
CactusWill
The dimmer is fine. Additionally the trunk light and hood lights are included in this deal as not working.
And will a mod please clean this thread up for me, I really need to get this fixed.
Old 10-03-2008, 08:09 PM   #13
check the accesorry fuses under the hood, replace all the acc fuses, i had em beofre that didint look blown but they were...
Old 10-03-2008, 08:13 PM   #14
umm_i_forget_14
umm_i_forget_14's Avatar
umm_i_forget_14 is on a distinguished road
Send a message via MSN to umm_i_forget_14
mine does the same thing, but it only does it randomly, but when they are working my stario stays on when i turn of the car and my horn honks when i lock with my fob, but when they arnt working my stario turned off like its supposed to and there is no sound when i lock with my fob
umm_i_forget_14 is offline   Reply With Quote
Old 10-03-2008, 08:28 PM   #15
umm_i_forget_14
...sry to jump in on ur problem i just figured we might have the same problem
Old 10-03-2008, 08:38 PM   #16
supposed to honk with the Fob...
Old 10-03-2008, 08:42 PM   #17
so if the dimmer is fine... then its gotta be something between the lights and the dimmer.
check this thread... i was having similar issues not to long ago.
http://www.aleromod.com/forums/showt...tracing+shorts
Old 10-03-2008, 09:57 PM   #18
undecided02
undecided02's Avatar
undecided02 is on a distinguished road
have you checked your actual wiring? I'm no expert but I do know that if they are all run in a series circuit then any damage to the wire would affect all your lights.
Spinnin wrenches or spinnin tires, everythings better on pavement.
undecided02 is offline   Reply With Quote
Old 10-04-2008, 12:54 AM   #19
Chipmunk-Alero
AleroMoB
Chipmunk-Alero's Avatar
Chipmunk-Alero is on a distinguished road
Send a message via AIM to Chipmunk-Alero
If you have all good fuses, u prolly just got a short in the box somewhere, check all of the bolts, metal tends to cause shorts.
2001 Oldsmobile Alero 4Dr GL2 w/ 2005 GAGT Motor
CC & PB, Tinted Tails, 3K HIDs (Lows/Fogs), GAGT Mirrors, Flowmaster Exhaust, D/S Rotors, CAI, Rockford Fosgate T400-4 T800-4, 1 15" C3, Rockford F 5.25/R 6x9
Chipmunk-Alero is offline   Reply With Quote
Old 10-04-2008, 02:35 AM   #20
Did you check the "INT LPS" fuse in the passenger side fuse panel?
