Old 10-26-2008, 08:03 AM   #1
KenshinZero
KenshinZero's Avatar
KenshinZero is an unknown quantity at this point
AGX Struts, What springs?
I did some looking, and I didn’t see anything related to this, what springs would work best with the KYB adjustable struts, for a daily driver, something moderately stiff, comfort is not much of an issue. Any help will be golden, thanks!!!
1999, RED Alero GX
KenshinZero is offline   Reply With Quote
Old 10-27-2008, 02:03 AM   #2
H&R (you have to look for them under a grand am)
Old 10-27-2008, 08:15 AM   #3
jabartram
AutoCross Alero
jabartram's Avatar
Intrax, i've had them for yrs, they are great.
Old 10-27-2008, 09:40 AM   #4
H&R ftw!!!
Old 10-27-2008, 10:21 AM   #5
guiguilandry
guiguilandry's Avatar
I gotta say, the eibach pro-kit is the damn best kit Ive seen so far, even with my 19s and the kyb gr2 the ride is even smoother yet tighter than the original
Custom or Nothing...
www.demonautosport.ca
Old 10-27-2008, 05:33 PM   #6
KenshinZero
Any one know anything about sprint springs? Just wondering. Thanks BTW.
1999, RED Alero GX
Old 10-28-2008, 12:22 AM   #7
Spilner521
Boost Guru
Spilner521's Avatar
I would say Sprint springs are the way to go, but that's because I have them Seriously though, they drop almost 2 inches and are a good bit stiffer than stock. Even on my stock struts they help the car handle pretty well. I'd buy them again.
Old 10-28-2008, 09:33 AM   #8
mfuller suspension guru says H&R
Old 10-28-2008, 10:16 AM   #9
kinda a dumb question... but...
i have 15" stock rims right now. If i got sprint springs (for example) and 18" rims... the body of the car will drop 2" but the rims will raise it another 3? Obviously this closes the wheel gap, but i'm just wondering how much lower the actual bottom of the car is, as compared to stock. It seems (from my logic) that the actual body of the car, will be 1" higher with that kinda setup...
(my logic behind NOT getting springs has always been, that i currently have "bottoming out" issues in many parts of the local area, so lowering would only make things worse)
or am i completely dellusional like usual.
Old 10-28-2008, 12:34 PM   #10
Wow, and they're going to let you diagnose and treat people
When you go to a larger wheel size, your overall outer diameter of the tire will roughly stay the same, so your ride height doesn't change all that much. Bigger wheel = less sidewall.
Old 10-28-2008, 12:42 PM   #11
aahhh... thats the part i was missing. (i was assuming same side wall size... which, duh, doesn't happen) even i was looking out the window at my car, and looking at ion's on the main page and scratching my head, at how stupid of a question that was.
hey! medical diagnosis is easy.. automotive anything is tricky. there is no rhyme or reason, engineers just do, and let people figure it out later.
Old 10-28-2008, 12:46 PM   #12
tnalero99
tnalero99's Avatar
tnalero99 is an unknown quantity at this point
^ Plus your axle is in the same location so the radius is the only variable that may change. 3 inch bigger wheel is equal to 1.5 inches of lift. From 16 to 18 inch wheels didn't change speedometer cause circumference is relatively the same by going down in tire height.
99 3400 V6, Black, 2 Door, eibach springs, TOG headers, 18" chrome wheels, clear corners, tinted windows and tails, CAI, taylor wires, 2-12" subs, tv w/ 12 disc, slotted rotors, soon to be OSV kit.
tnalero99 is offline   Reply With Quote
Old 10-28-2008, 12:47 PM   #13
That's almost sig-worthy right there!
Old 10-28-2008, 09:29 PM   #14
KenshinZero
No question is a dumb question, unless you ask the same question twice!
1999, RED Alero GX
Old 10-28-2008, 11:30 PM   #15
Spilner521
Boost Guru
Spilner521's Avatar
You'll be fine. I've driven all around WNY for 3 years lowered on 18's, even in the snow, with no problems. Yeah you'll get the occasional scrape here and there, just be careful going up and down steep driveways.
Old 10-29-2008, 06:51 AM   #16
problem being, i'm in downtown buffalo all the time now, and if i'm not careful, i scrape (bad) being stock. i've heard some small SUVs scrape. so i guess i'll just save my money on those mods....
Old 10-29-2008, 12:50 PM   #17
While you won't get the look of being lowered, some stock FE3 springs and AGXs would surely increase the handling.
Old 10-29-2008, 02:04 PM   #18
agx's are way out of my price range.... you apparently think i'm one of those "rich" college kids.
Old 10-30-2008, 01:44 AM   #19
It's called budgeting...... I guess you didn't take that class
Old 10-30-2008, 07:00 AM   #20
its also called priorities. my car doesn't need $500 struts... however, i do need to eat, and fill my gas tank so i can get back to school.
