Old 03-12-2009, 09:31 PM   #1
tudski
tudski is on a distinguished road
quick question
aright so my battery in my alero is the type were the pos. and neg. screm into it, and i was wondering if the posts that u use to screw into the battery have a charge so that i can put a post terminal on it run a power wire. might not understand wat im saying but i can find a picture of the correct battery to point out wat im asking.
tudski is offline   Reply With Quote
Old 03-12-2009, 09:32 PM   #2
u talking about for an amp
Old 03-12-2009, 09:36 PM   #3
tudski
yeup and i need to know if it put outs current at that post.
Old 03-12-2009, 09:45 PM   #4
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
Yes, you connect your amp's power wire to the positive post. With a fuse.
Misuseofyou is offline   Reply With Quote
Old 03-12-2009, 09:52 PM   #5
tudski
so that post does have a charge? cause i have the power wire just wedged in between the bushing(car powerwire for component stuff..ie. starter, etc) and the terminal
Old 03-12-2009, 09:54 PM   #6
ur gonna need a fuse, if ur usin an amp kit it should come with one
Old 03-12-2009, 09:58 PM   #7
tudski
i know i have it already setup its working but i want to make it look nicer clean up the wires, so thats why i was wondering.
Old 03-12-2009, 10:01 PM   #8
Misuseofyou
Its hard to understand what you mean. You crimp then solder a ring terminal on the end of your wire, then unscrew the post, put the ring on the bolt and screw it back in.
Old 03-12-2009, 10:05 PM   #9
tudski
thats what i have now done but i want to get somethign liek this so i can have multiple runs to multiple amps
http://www.sonicelectronix.com/item_...+Terminal.html
Old 03-12-2009, 10:22 PM   #10
my freinds amp kit came with that
Old 03-12-2009, 10:24 PM   #11
AbHeLlRaZoR
Canada's Ghost
AbHeLlRaZoR's Avatar
you can use a different type so that you don't have to run multiple power cords to the trunk. EDIT: Try a Distribution block
Old 03-12-2009, 10:26 PM   #12
Misuseofyou
I have 4 diff wires connected to my positive terminal without buying one of those.
