03-13-2009, 04:13 PM
Fiberglass
I'm wondering if a phenolic spacer could be replaced with fiberglass? I could get the resin and some sheets of fiberglass, stack them up until they get to about 1/4 inch thick, then cut to size. Any thoughts?
03-13-2009, 04:16 PM
just use phenolic material
03-13-2009, 04:17 PM
it is possible, i know somebody running a custom set that are 1/4 mdf with a coat of high heat paint.....
03-13-2009, 04:18 PM
I'm in the process of getting some, just throwing the thought out there. Kind of curoius if there is an easier, better way.
Hmmmm, mdf?
03-13-2009, 04:22 PM
Wow, didn't even think of that. That's about as basic as it gets.
03-13-2009, 04:24 PM
and as cheap, problem is replacement, he replaces his about every 6 months, but that' no biggie, i think my top end only usually makes it about 3 months everytime I reassemble....
03-13-2009, 04:26 PM
Well, I can see how it wears out so fast, being wood and all.
03-13-2009, 04:28 PM
not so much the wood you worry about, it is if the paint starts to chip, that's usually not healthy for an engine, not really bad, but not great either.....
when i grenaded my piston, i only had half of it in the motor still, the other half went out the tailpipe.....lol
03-13-2009, 04:30 PM
so what's the deal? are you just dieing to make something or what?
what kind of equipment do you have, plasma, tig, mig, waterjet, cad?
03-13-2009, 05:10 PM
Pretty much, and I do not have any of that, except CAD. I've got some connections to that kind of equipment, and it helps that I can get material through where I work.
03-13-2009, 06:45 PM
Fiberglass wont hold up to the heat, period.
03-13-2009, 07:50 PM
I'm not talking about the same kind of fiberglass used for body work. There are different grades of the stuff. Like I said, I need to look into it some more.
03-13-2009, 09:14 PM
I made 1/2 inch spacers out of basswood, sprayed color on and urethane varnished 'em. had them about three years now.
03-13-2009, 11:07 PM
i could have sworn it was mdf and that you had changed them several times, well i'll be damned.......
