Old 03-24-2009, 11:53 AM   #1
CactusWill
Ignition Switch Relearn
When you do a relearn on the ignition switch, does it start over every time as if the switch were brand new? Or does the data from the initial relearn always stay in the switch?
Old 03-24-2009, 12:40 PM   #2
You should only have to do it once. Only when one of the components is replaced.
Old 03-24-2009, 01:20 PM   #3
CactusWill
That wasn't quite what I was asking, but almost.
So the first time you relearn the switch, does that relearn stay there permanently, or can it be relearned again as if it were a new switch?
Old 03-24-2009, 01:26 PM   #4
Hmm...
The relearn is performed after the "password" between the passlock cylinder and BCM no longer coincide with each other.
When the relearn is performed, the new "password" is stored and the old one is erased from the memory.
As long as the "password" matches between the BCM and the Passlock cylinder, then no relearn procedure is required.
Old 03-24-2009, 01:33 PM   #5
CactusWill
That is still not answering my question
Old 03-24-2009, 01:39 PM   #6
Then what is your question?
Old 03-24-2009, 01:48 PM   #7
CactusWill
I asked it twice already
Old 03-24-2009, 01:53 PM   #8
comanche
comanche is an unknown quantity at this point
So, you wonder if a used switch can be relearned..... ?
Yep, pretty sure on that. If you take a switch that has been used, and go to relearn it on another car/bcm, it should relearn just fine... you just have to go through the 10 minute procedure again.
So i think the answer to your question would be yes, it can be relearned again as if it were a new switch.
comanche is offline   Reply With Quote
Old 03-24-2009, 02:04 PM   #9
CactusWill
Thank you commanche.
Old 03-24-2009, 04:06 PM   #10
comanche
Anyone disagree with me? I have done basically the same thing, with a used bcm and a used ignition module, i didn't need a new ignition module when i installed a used bcm, i just had to go through the relearn procedure.
Old 03-24-2009, 06:40 PM   #11
wearetheromans85
wearetheromans85's Avatar
wearetheromans85 is on a distinguished road
just bypass the passlock crap. no relearn or security light ever again.
wearetheromans85 is offline   Reply With Quote
Old 03-25-2009, 01:40 AM   #12
Ohh.. I was misunderstanding the question. The switch doesn't have any part of the learning in it. It's all controlled by the BCM.
So to answer your question:
"Will my passlock still function correctly if I replace my ignition lock cylinder with a used one".
The answer is yes.
Old 03-25-2009, 11:31 AM   #13
CactusWill
That was not my question.
My real concern, was that when that I replaced the ignition switch with a new one, that it was not relearned correctly and I wondered if that ruined the switch, or if the switch can be relearned again as if it were new.
Old 03-26-2009, 01:50 AM   #14
Either way, the switch does no learning. The BCM learns the switch.
Old 03-26-2009, 01:59 AM   #15
CactusWill
Thank you. That helps alot more than, rewording and trying to assume what the original question really was. LOL
