11-14-2009, 07:57 AM
Rear Speaker Deck
GRR its ANNOYING! when i listen to heavy bass songs, the thing rattles, like plasti on
plastic rattle, it's very annoying, and i wondered what i could do about it, i cant find the source or the rattle, it seems like the entire back thing is rattling, what can i do?
11-14-2009, 08:27 AM
i thought mine did that... but it turned out to be a wire harness in the C pillar. Check those. One of the plugs that hold them to the sheet metal, wasn't clipped in.
hasn't done it since.
11-14-2009, 08:30 AM
AutoCross Alero
sound deadener, i used fatmat on the rear deck, under the back seat and the trunk and trunk lid.
11-14-2009, 09:21 AM
and you guys know this is the stock 99 rear amped DVC stereo right? i have no sub lol
where did you put the fatmat? i might try that
and all the clips are in place, i was just in both sides a week or so ago, to fix my rear defroster
http://www.youtube.com/watch?v=xYHgWwxV0DY
that's the sound, it's so annoying
11-14-2009, 10:15 AM
oh cuz i have my new amp 2000whts plugged up to my cf1244 and it moves my shole back! is it you plate on the back of your car?
 any help with my car i will look in on and love!
11-14-2009, 02:06 PM
AutoCross Alero
i removed the carpeted deck cover, the back seat bottom, and all of the trunk carpet and fat matted all of the metal, top part of the deck only.
11-14-2009, 08:54 PM
check the speakers, may have blown one, and if they are DVCs then 1 coil may have blown
11-14-2009, 09:48 PM
nah, its th deck, if i put my hand on it, it stops, i just wanted to know what to do about it
11-14-2009, 10:13 PM
dapener, dynamat, or some other kind of cushion in between
11-14-2009, 10:14 PM
AutoCross Alero
fatmat, inexpensive on ebay. http://cgi.ebay.com/10-Sq-Ft-50-Mil-...15135wt_633 5
11-14-2009, 10:16 PM
11-14-2009, 11:06 PM
or you could fiberglass a new one. xD take out carpet soft one, replace with mad hard beauty plate baller style. ye son
Officially addicted to bass.
11-14-2009, 11:50 PM
A little off topic, but isn't that sub rated at 400 watts rms, not 2000?
And rattle issue, i gave up with my subs beating up the rear deck. But with your setup only being stock with no subs to worry about, sound deadener would be your best option. Just go with the forum discount cheery pointed out or pick something up cheap off of eBay.
Under construction...
11-15-2009, 01:31 AM
i put some thin foam weather stripping between the deck and window and the rattle stopped
