Old 12-06-2009, 07:57 PM   #1
RideRedAlero
RideRedAlero's Avatar
RideRedAlero is on a distinguished road
CD and Head Unit Question
I was told by someone that does audio installs that if i purchased a JVC cd player($140) that I would have to pay $40-60 bucks just for special wires also. He told me that Alero's have different and special wires that are more expensive. Is this true at all?
RideRedAlero is offline   Reply With Quote
Old 12-06-2009, 08:18 PM   #2
Chipmunk-Alero
AleroMoB
Chipmunk-Alero's Avatar
Chipmunk-Alero is on a distinguished road
Send a message via AIM to Chipmunk-Alero
^^FAQ's mothereffer, do you read them??
Hahaha, seriously though the search button is your friend.
2001 Oldsmobile Alero 4Dr GL2 w/ 2005 GAGT Motor
CC & PB, Tinted Tails, 3K HIDs (Lows/Fogs), GAGT Mirrors, Flowmaster Exhaust, D/S Rotors, CAI, Rockford Fosgate T400-4 T800-4, 1 15" C3, Rockford F 5.25/R 6x9
Chipmunk-Alero is offline   Reply With Quote
Old 12-06-2009, 08:23 PM   #3
dude, dont just say "search" and not tell him... it's an honest mistake
yeah, you need something called a "chime module" or you an use a relocate harness, and keep your existing HU in the trunk, if you do not do either, you will not have chimes....
Old 12-06-2009, 08:46 PM   #4
MotorCity
MotorCity's Avatar
MotorCity is on a distinguished road
if can remember to take your keys out put gas in the car and close your door you don't really need it i dont
I am beyond help...
MotorCity is offline   Reply With Quote
Old 12-06-2009, 08:53 PM   #5
RideRedAlero
Is this the name of the part GMRC- 02
Old 12-06-2009, 09:24 PM   #6
RideRedAlero
so the only thing it does is stop the chiming?
Old 12-06-2009, 09:36 PM   #7
AndyT3
AndyT3's Avatar
AndyT3 is on a distinguished road
Send a message via AIM to AndyT3 Send a message via Yahoo to AndyT3
Yes, but those chimes are also used to help you reset your oil life and tire pressure monitor. Also, to change your automatic door locks, like all unlock on key off, of just drivers unlock on key off, and stuff like that. The chime goes off a number of times, which corresponds with a setting. All in all, you should get the module to keep your chime.
FQuick - updated all the time
AndyT3 is offline   Reply With Quote
Old 12-07-2009, 01:16 PM   #8
as for the tire pres and oil life, there are lights for those. push the button til the one you want blinks, hold down the button, the light goes out. simple, screw the chimes.
all the chimes are really for is your keys, low gas, lights, and close the damn door. there are lights on for all of them except the keys, but those are obvious. just get the cheap harness and lose the chimes.
Old 12-07-2009, 04:45 PM   #9
RideRedAlero
I also heard that the head unit itself that goes with the cd players for Alero's are more expensive then normally. Is this true also?
Old 12-07-2009, 04:58 PM   #10
Any head unit will fit, you just need to MAKE it fit.
There is a plastic "case" which our HUs sit in. Cut it, rip it, break it- just clear the path. Theres also a metal strap back there, I cut mine out.
Ive heard the later Aleros also do not have a switched 12V wire in the stock harness.
Just buy the module. They run about $60 as stated, thats at dealer cost even.
Old 12-07-2009, 06:46 PM   #11
colonel6632
colonel6632's Avatar
ryans right. my 2002 doesn't have switched 12v. i had to buy the $60 module for the car. makes hooking up the deck really easy. but what sucks is if you blow the module like i did. it now doesn't have 12v switched.
Old 12-07-2009, 07:05 PM   #12
DansGen1Alero
DansGen1Alero's Avatar
DansGen1Alero is an unknown quantity at this point
Send a message via AIM to DansGen1Alero Send a message via Yahoo to DansGen1Alero Send a message via Skype™ to DansGen1Alero
99s dont need any of that at all, just normal wire harness 19.99
www.myspace.com/dansgen1alero
www.nicedreamscc.com
"Vinyl belongs on the side of a house not on a car"
DansGen1Alero is offline   Reply With Quote
Old 12-07-2009, 09:48 PM   #13
I have a 200 and its the same way.
If you are planning on buying a new radio pm me for a quote. If you buy the radio and harness through me I will solder it all up for you. All you will have to do is slap it in there. I got fit kits available also.
