Old 11-24-2011, 02:52 PM   #1
jalero
jalero is on a distinguished road
Alero Wet carpets, sloshing water. Fixed !
I've had this 01 Alero for 18 months and 5,000 miles (70k).
Early on, I found that the carpet(s) were 'soaked' periodically .
Once, after a heavy snowstorm, I could hear the water 'sloshing' below the passenger floorboards. The carpets were NOT wet.
This always occurred while NOT driving. The Alero was parked.
Other times, the driver and passenger side carpets were soaked. Sometimes the water would migrate to the rear carpet.
After many internet searches and the possible solutions, I felt I was at an end-point.
A couple of weeks ago, I noticed that the windshield gasket had pulled away from the lower portion of the glass at two locations. This left a gap between the top of the gasket and the lower edge of the glass.
Looking the situation over, I saw that there was a channel below this 'gap' that looked as though it may allow the water to migrate to another, unseen area.
I waited for a somewhat warm day and refitted the gasket onto the windshield.
After several rains and one very heavy thunderstorm, I am happy to report that the problem seems to have been repaired.
My Airbag SRS module went into 'fault' mode toward the end of this process. I pulled the module (under passenger seat) and it was obvious that moisture was a problem. Water was 'puddled' under the module and the module was quite corroded.
This is what lead me to attempt to finalize the moisture problem.
Hopefully others will be saved some aggravation.
jalero is offline   Reply With Quote
Old 11-26-2011, 04:36 PM   #2
zzyzzx
zzyzzx's Avatar
Anyone got a fix the wet carpet in the trunk?
Old 11-26-2011, 06:50 PM   #3
Williamleo
Williamleo's Avatar
Williamleo is on a distinguished road
Send a message via Yahoo to Williamleo
On my girl's Alero, the rubber weather stripping around the trunk had moved. She had about a gallon of water in her spare tire holder. We got it all out and she noticed the rubber was pulled away, just a little. She pushed it all into place, problem solved!
In the neighborhood of B...
Williamleo is offline   Reply With Quote
Old 11-26-2011, 09:14 PM   #4
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
I pulled the carpet from my trunk. no more wet carpet.
Old 11-27-2011, 08:41 AM   #5
strtrydr
strtrydr's Avatar
^ Genius!!! ... lol
Old 11-27-2011, 10:33 PM   #6
Christato71
Christato71's Avatar
Christato71 is on a distinguished road
Send a message via ICQ to Christato71 Send a message via AIM to Christato71 Send a message via MSN to Christato71 Send a message via Skype™ to Christato71
I had the same exact problem. I had to fix the weather stripping a swell as use a little epoxy on a few rusted areas under the truck lid.
http://www.aleromod.com/forums/showthread.php?t=33900
Blog
Christato71 is offline   Reply With Quote
