Old 01-23-2012, 01:23 PM   #1
trans question
I'm looking to change the trans soon. Its starting to slip, I'm looking at a gagt trans. Question is will I run into any issues?
Old 01-23-2012, 01:28 PM   #2
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
As far as I can see, your PCM needs to be adjusted for the change in gear ratio. Also I remember reading that 03+ 4T45E trannies were upgraded with stronger internals for reliablity or something of that matter.
Old 01-23-2012, 02:04 PM   #3
How do I adjust it
Old 01-23-2012, 02:21 PM   #4
Tuning software like hptuners
I have a gagt tranny in my car's nd the tranny shop did it
Old 01-23-2012, 03:42 PM   #5
zzyzzx
zzyzzx's Avatar
Have you tried changing the fluid and filter on your existing transmission?
Have you tried a fluid conditioner?
Is the transmission fluid pressure adjustable on these things?
How many miles are on this transmission?
I have over 206,500 miles on a vintage 1995 Ford Escort automatic transmission, and that's in Baltimore - Washington DC traffic too.
Old 01-23-2012, 06:05 PM   #6
Honestly I'm after the different final drive ratio
Old 01-23-2012, 06:15 PM   #7
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Have you driven a GAGT to see the difference? I'd start there first to see it it's really worth the trouble.
Old 01-23-2012, 11:10 PM   #8
Well in found a low mileage lx9. For 200. And I'm looking to put the gagt trans up to that moter
Old 01-23-2012, 11:11 PM   #9
unchained01
unchained01 is on a distinguished road
GAGT ratio is 3.29
unchained01 is offline   Reply With Quote
Old 01-24-2012, 09:39 AM   #10
No offence but this is a Oldsmobile were talking about here on a Oldsmobile alero forum, the alero is nothing like the escort that you make reference to quite frequently on this board, they are compleatly different cars, yea the escort is a fine car, so just because it gets better mileage out of some parts because of its lighter weight doesn't make it a good comparison vehical to a heavy alero. Just my input,
Old 01-24-2012, 09:42 AM   #11
I wonder if I grab the gagt pcm if it would work on the alero
Old 01-24-2012, 09:56 AM   #12
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Not really no... Your PCM has your VIN flashed into it as well so, your car wont really like having a PCM with a VIN other than your own. To be honest your better off getting it reflashed anyways because then you can also fine tune your car and quite possibly gain a bit of HP in the process.
Old 01-24-2012, 11:17 AM   #13
pm reddog he has a GT tranny in his alero i am pretty sure.
Old 01-24-2012, 11:23 AM   #14
How did you get your trans to work, any noticeable difference?
Old 02-22-2012, 12:59 PM   #15
dbailey
dbailey is an unknown quantity at this point
When is it slipping? Mine is slipping from a dead stop if I even slightly accelerate hard. I think it is the front tranny mount that has bit it and may be the cause. At least that is what the tranny guy said.
dbailey is offline   Reply With Quote
Old 02-22-2012, 01:14 PM   #16
There really is so little difference between the two that I would just put another 40 in it... just my 2 cnts. I had the 40 in my se and a 45 in the 00. Comparing the tables, there is really not that much difference.
Old 02-22-2012, 07:21 PM   #17
HAHA No, not yet, but I do plan on putting one in later.
With HPTuners, you can change the gear ratio in about 2 seconds. All the drive gears are the same it's just the FDR.
The nice part about the 4T45 tranny is that they are still using it today! It's used in the New Malibu, the G6, and a few other cars. I know it's also in the G6 4 cyl and the Cobalt with a 3.90 FDR. There is also a 3.61 ratio too.
Fuller has a 3.42 in his car and it's a bit much for a stock engine. He has the next cam up from what I'm putting in. His I believe is a custom job though.
For what I'm doing the 3.29 is a perfect fit. The 3.61 which is next, is too much for my taste
Old 02-24-2012, 08:17 AM   #18
mastershake
mastershake's Avatar
mastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond repute
^ so if newer cars are still using the same transmissions, could we swap in a brand new/slightly used one? are they backwards compatible?
mastershake is offline   Reply With Quote
Old 02-24-2012, 10:25 AM   #19
^^ That was my point
Old 02-24-2012, 10:59 AM   #20
mastershake
right. i was just wondering if they'd be PERFECTLY compatible since they upgrade over the years. then again i'm just dumb xD
