Old 02-10-2007, 11:09 PM   #1
I'm starting this page here, and after it gets enough info, it can be moved and/or stickied. The VIP version can be deleted. Moved into the public forums so everyone can contribute. But please, don't post skim, and only add something that applies. This isn't the final cut, just a figurative page until someone can make a more web-based model.
Q) How do I install an aftermarket radio?
http://www.aleromod.com/forums/showthread.php?t=247
Q) How do I clear my headlights?
A) http://www.aleromod.com/forums/showthread.php?t=10
Q) What size bulbs fit where, in the alero?
A)
Q) What size rims fit my Alero?
A) Stock
215/60R15 25.2" dia (1999-2003)
205/65R15 25.5" dia (2004)
225/50R16 24.9" dia (1999-2004)
Aftermarket
225/40/18
225/45/17
(some slight variations may apply)
Q) How do I do anything with LED's?
A) Basic Wiring...http://www.aleromod.com/forums/showthread.php?t=8404
and http://www.aleromod.com/forums/showthread.php?t=12755
Wheel Wells...http://www.aleromod.com/forums/showthread.php?t=14683
In the Doors... http://www.aleromod.com/forums/showthread.php?t=8297
Window Switches...http://www.aleromod.com/forums/showthread.php?t=9056
Gauge Cluster...http://www.aleromod.com/forums/showthread.php?t=1990
Led Needles... http://www.aleromod.com/forums/showt...ht=led+needles
Vents...http://www.aleromod.com/forums/showthread.php?t=5350
HVAC controls...http://www.aleromod.com/forums/showt...light=Hvac+led
Door Switches...http://www.aleromod.com/forums/showt...highlight=neo3
Q) I changed my gauges to leds, but they have a weird bluish tint...
A)It can be sanded off...
http://www.aleromod.com/forums/showp...9&postcount=35
Q) Ok, I just changed some turning signal lights to LEDs, and now they blink like crazy. Why is that?
A) The car puts a much higher load through the line for regular blubs. You need a Load Resistor in line. http://www.superbrightleds.com/tail-brake-turn.html at the bottom of the page.
Q)What size battery fits my alero?
A) 75/35 for top and front battery terminals.
Q)Whats better, Cold Air Intake or Warm Air Intake?
A) Depends on what you want to do, and where you live. http://www.aleromod.com/forums/showt...ht=cold+intake
Q)I found a miracle product on ebay! How much better will my horsepower be?
A) It won't improve at all. http://www.aleromod.com/forums/showt...highlight=ebay
Q) What body kits are available?
A) Razzi, AAS(aka Kombat Kit) and Forbidden
Q) I've never heard of the Forbidden kit...
A) Look here if you want to know why it has been termed, as such.
http://www.aleromod.com/forums/showthread.php?t=853
Q) My fans don't work an anything but high. Whats wrong and how do I fix it?
A) Your blower motor resistor is blown.
http://www.aleromod.com/forums/showt...ghlight=blower
Q) My hazard switch doesn't work...
A) There was a recall on several 2000-2001 aleros. You can check GMs website with your Vin, or do it yourself.
http://www.aleromod.com/forums/showt...=hazard+recall
For ordering use part number: 10359040
Q) I want more horsepower! how do i increase that?
A) http://www.aleromod.com/forums/showthread.php?t=6217
Q) I have an Ecotec... Where is info for my engine?
A) http://www.aleromod.com/forums/showthread.php?t=38
Q) I have a 3400, changed my oil, and its an odd coffee color... my coolant also seems low.
A) You have the dreaded Lower Intake Manifold Gasket leak. Your coolant is leaking into your oil. http://www.aleromod.com/forums/showt...ake+mani fold
How to fix it: http://www.aleromod.com/forums/showt...ake+manif old
And
http://www.grandamgt.com/forum/showthread.php?t=68087
AND
http://d-tips.com/general/articles/article.aspx?id=2
Paint Code:
Originally Posted by Cliff8928 View Post
If you look on your spare tire cover, the paint code is located on the Service Parts Identification Label.
This isn't complete but I can't think of any more. If someone is going to correct any of this info, please site specific details and sites, not yourself. Also, any additions posted, please keep the same format. (unless an admin wants to clean this up some) I also have to repost pictures in my How to Led threads.... They didn't make the move to the new server...
Old 12-13-2008, 08:35 AM   #2
need to add fog light bulb...894 sylvania.
Old 06-14-2009, 04:25 AM   #3
Oldsman
Owner
Oldsman's Avatar
Passlock reset.....................
YOU CAN FIND THE EXACT PROCEDURE ON PFYC.COM UNDER THE DHP V1.0 CHIP.
If not here is the procedure:
1. Try to start the car. If car doesn't start DO NOT TURN KEY TO OFF!!! ... Leave in RUN position.
2. Wait for no less than 10 minutes.
3. Turn Key to OFF.
4. Wait for no less than 1 minute.
5. Try to start the car again. If it doesnt work now. follow the steps again.
Could take up to 4 times before the car will fire again.
Beware of the BackStabber
Old 02-12-2010, 04:00 PM   #4
3. Turn Key to OFF.
all I did when it did that to me was remove the security fuse for about 5 minutes, and put it back in. Worked for me.
Old 11-28-2010, 10:13 PM   #5
McMarcus
McMarcus's Avatar
McMarcus is on a distinguished road
Dang Dude, You really know you stuff on Aleros. Props 100%
-8000K DDM HID Kit
--Tinted Tails
---AVS headlight covers
----MTX SUBS, Pioneer Head-unit.
---Blue LED's
--White-painted Bezels
-Clear Corners
--More to come.
McMarcus is offline   Reply With Quote
