Old 03-26-2009, 01:47 PM   #1
CactusWill
What Else Could It Be?
Fan switch only works on highest setting.
Replaced the blower motor resistor chip, the control switch, and the motor does work on high speed.
So are there any other components that it could be? Besides just bad wiring somewheres?
Old 03-26-2009, 02:13 PM   #2
check the harness, to make sure all the contacts are clean/straight? (on both sides)
Old 03-26-2009, 02:15 PM   #3
Could be the blow motor itself!
Old 03-26-2009, 02:22 PM   #4
CactusWill
But it works?
Old 03-26-2009, 02:27 PM   #5
Originally Posted by CactusWill View Post
But it works?
It only works in the highest setting. Doesn't necessarily mean that it works fully. It could very well not be the blow motor itself but I figured that mine as well check everything...cover all bases so to speak. Are you sure the blow motor resistor you have isn't faulty?
Old 03-26-2009, 02:53 PM   #6
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
yeah mine only starts putting out air when its on the last three settings and then sometimes when I am driving I can feel it blowing air out and the things off
cliffordwoeller is offline   Reply With Quote
Old 03-26-2009, 03:24 PM   #7
CactusWill
I really don't think it is bad. When it was replaced with a new ac delco one after I first got the car, the mechanic said that the last resistor was also brand new.
Old 03-26-2009, 03:47 PM   #8
i dont trust mechanics. When I bought my car everything they said they did I had checked and or redone....but to each his own....only other thing you can do is to start checking the hvac controls to make sure everything is plugged in. Check the blow motor resistor to see if it is plugged in correctly. Check the blow motor relay to make sure it is fine as well, should be under the hood.
Old 03-26-2009, 04:05 PM   #9
CactusWill
I watched it done, I know the guy, I saw that the 'old' resistor was already a replacement. He said the new one probably wouldn't do any good, put it in, and then nothing. The fuses and relays are good too.
Old 03-26-2009, 11:43 PM   #10
CactusWill
bump, gotta take care of this
Old 03-27-2009, 12:16 AM   #11
IDK, I would just take a stab at the connection to the switch. My Alero didn't like that being unpluged at all
Old 03-27-2009, 12:23 AM   #12
CactusWill
already done
Old 03-27-2009, 02:01 AM   #13
Do you have a test light or multimeter to check it out?
With the blower resistor connected, check for power at pin E on the resistor (dark blue wire)
This is also pin 87A on the relay in the underhood junction block.
Old 03-27-2009, 01:54 PM   #14
Blackfly99
Blackfly99 is an unknown quantity at this point
Send a message via MSN to Blackfly99
I had the same issue as well. After replacing the resistor and checking all the connections it turned out it was the blower motor itself.
See it Love it Live it-99 Black Alero 2Dr
Clear HVAC Guage-Silver detailed interior
Tints-16" E1 Zeus Rims
Clear Corners
Blackfly99 is offline   Reply With Quote
Old 03-27-2009, 02:14 PM   #15
CactusWill
But it still worked on high?
Old 03-27-2009, 03:29 PM   #16
Blackfly99
Still worked on high just made a weird sound on the highest setting...after a couple of months it just stopped working all together.
Clear Corners
Old 03-27-2009, 03:57 PM   #17
CactusWill
Yeah this one works fine on high. Doesn't sound like its going out.
Old 03-27-2009, 11:56 PM   #18
odds are that its a blower motor
Old 03-27-2009, 11:59 PM   #19
considering the evidence presented... i'd agree. bad blower motor.. again.
its happened before on here. someone replaced it, only to have it die immediately again.
has anyone ever figured out WHY it burns out?
Old 03-28-2009, 05:00 AM   #20
CactusWill
Checked it out. One of the relays was still good, but unfortunately it was the wrong one. LOL
Thanks guys.
